10.30.2008, 11:26 PM
Here is the info with the outrunner, anyone care to guess if an axi 2826/12 would work well with this heavy rig?
Differential Ratio: 2.8461538461538462
Transmission Ratio: 2.769230769230769
Other Ratio: 1
Spur Tooth Count: 72
Pinion Tooth Count: 14
Total Voltage: 14.8
Motor KV: 760
Tire Diameter (inches): 6.5
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 5.14 : 1
Total Ratio: 40.53423 : 1
Tire Circumference (inches): 20.42 inches (518.68 mm)
Total Motor Speed: 11248 RPM
Vehicle Speed: 5.37 mph (8.62 km/h)
