Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
10.31.2008, 11:18 AM
Just a warning guys...you'll need a super powerful iron to desolder those bullets, and with the amount of copper in the PCB, you risk melting solder on other components on the board (as I once learnt with my MM). If this is really causing an issue, I'd just bend the relevant heatsink prongs out of harm's way, and maybe just shrinkwrap the plugs IMO?
I must admit, I can't see how a that socket would've been able to flex the PCB so much as for it to touch the PCB as it's so light (it would take a relatively high impact on the plug for that to happen...or at least, that's how it seems to me), so from where I am it sounds more likely that the plug slipped out and shorted. But even then, Patrick's said this shouldn't be able to happen, so I dunno. Strange...
