11.01.2008, 10:41 PM
Originally Posted by Desmo View Post
You know the heat sink is not part of the elec circut in the esc. So if it did touch the connector nothing should happen. Also since it is alum it would have more blown out of it than the bullet if it was part of a short. I think the bullet connector was the problem here.
True, the HS is not part of the circuit, but it can act like a bridge if two bullet connectors touch it at the same time. But yeah, you'd think the HS would show more arc pitting than the bullet if that was the case.
