11.02.2008, 06:00 PM
Ryan has been offline for quite some time. *Cough* not sure why.
A RC Dude
A RC Dude's Avatar
11.02.2008, 10:50 PM
Well my pede hasn't had much attention lately so I gave it a bit of a make over...
I think the motor (CC 1515 1Y 2200) is overkill but needed to run it in something - I can't get a MMM in there though as the motor wires aren't long enough so opted for a trusty MM.
I inverted the RPM bumper and added some lead to help keep the front end down. I think I may have to lose the wing but will see what happens... I checked and it looks like a revo 2.5 body that I have will fit pretty well if I lose the wing...
Any other suggestions?
Differential Ratio: 1
Transmission Ratio: 2.727272727272727
Other Ratio: 1
Spur Tooth Count: 40
Pinion Tooth Count: 20
Total Voltage: 18.5
Motor KV: 2200
Tire Diameter (inches): 4.1
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 2 : 1
Total Ratio: 5.45455 : 1
Tire Circumference (inches): 12.88 inches (327.17 mm)
Total Motor Speed: 40700 RPM
Vehicle Speed: 91.01 mph (146.2 km/h)
Estimated Adjusted Speed: 79 mph (127 km/h) - 13% loss
Effective KV Value: 2200
Dang! Someone beat me to it! lol A wile ago i tried to get my 9xl to fit into my rustler but my swamibar was in the way and the 9xl wouldn't fit. lol
Nice PEDE tho!!! I'd really love to see a video of that thing run!!!!
11.02.2008, 10:56 PM
Lutach we need to meet up :)
Unsullied_Spy
Unsullied_Spy's Avatar
11.02.2008, 11:51 PM
I've already done this...insane power for the platform.
24/38 fit just fine and it had more than enough power, I could go to a 34T spur and whatever the biggest pinion is and still have power left. I wasn't able to get my Rustler completely set up for speed before this thing stripped a stub axle (twisted the U-joint right off). It's very heavy, but it goes like stink!
11.03.2008, 12:12 AM
Whoa.
A RC Dude
A RC Dude's Avatar
11.04.2008, 05:43 PM
JEEZ!!! That'll deff fly now
asheck
11.04.2008, 05:54 PM
Done this , been here :) only I was running a Novak 4.5. I only managed right over 70,then it was just to uncontrollable on foams.It would start drifting and correcting would make it go haywire. I did not run lead up front,I added a little wing to the bumper.It had no trouble keeping the front down.But it was very unstable. Good luck with this,I always thought it had 80 in it.For the diff you could try this http://cgi.ebay.com/ws/eBayISAPI.dll...%3D4%26ps%3D42 then use Jato shafts and your about as strong as it gets.
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.04.2008, 06:20 PM
Overpowered 2wd trucks are great.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
TheRandom1
11.04.2008, 06:25 PM
Overpowered trucks are great.
Fixed that for ya!
  Send a message via Yahoo to TheRandom1 Send a message via AIM to TheRandom1 Send a message via MSN to TheRandom1
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.04.2008, 09:21 PM
I like it better this way...
11.04.2008, 11:02 PM
Snell, your the king of overpowered 2wd trucks...
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.05.2008, 12:49 AM
The scary thing is that I can add 2 more A123 cells in the Rustler.
A RC Dude
A RC Dude's Avatar
11.05.2008, 09:16 PM
SHEW!! DANG!! I just thought about it and what if you took the tranny out and hooked an outrunner motor up directly to some really strong driveshafts and fitted bigger, more stable tires on it.
What's_nitro?
11.05.2008, 09:23 PM
Uhh, are you an R/C terrorist?? Why are you telling people how to build bombs!!!
brushlessboy16
brushlessboy16's Avatar
11.05.2008, 09:44 PM
all a rocket is is a controlled explosion
