bl-is-future
bl-is-future's Avatar
11.05.2008, 09:28 AM
dan there is really no way to get past that rub with the tvp spacers installed and them lst shocks. The shocks are just too damn big. You could try to move the top mount of the shocks but looking at the pics it is as far out as it gets. if all else fails put a piece of foam where it rubs and jsut replace the foam when it wears out.
saydee - yes check for any binding by moving the wheels to each side with your hands. Make sure the radio is off so you dont screw up your servo. If you can move it all the way than loosen the two screw that hold the entire try that the servo is on up a tad and try that.
