Pdelcast
Pdelcast's Avatar
11.05.2008, 06:23 PM
WHOA - Guys --
What we are trying to prevent is the fact that people are jamming screwdrivers into the slots on the case and breaking parts off the circuit boards, and ripping wires off circuit boards trying to "fix" issues that don't even exist. 80% of the V3 failures we have seen here at Castle on the V3s have been people who are freaked out about WHAT THEY HAVE READ HERE and have decided to implement a "fix" (for something which isn't a problem) and ended up damaging the boards.
If you are careful and open the case correctly, we don't have a problem with it. But we are reserving the right to DENY fixing under warranty if you are careless and damage the board by jamming a screwdriver into the case slots and destroy parts.
AGAIN, and I have said this like FIVE TIMES already -- there is no problem with the bullets and the heat sink. THERE IS NO PROBLEM WITH THE BULLETS and the HEAT SINK. DO I NEED TO SAY IT AGAIN???
AND so far we haven't seen any problem with the fan and wires on the new case either -- not a SINGLE case of wires even rubbing in the new cases-- but we have had 8 people destroy Monsters trying to "fix" the fan wire "problem" because of what they have read here in this forum.
SO -- don't open your case just 'cause you want to. You might break something.
Patrick del Castillo
President, Principle Engineer
