Question about your signature- you said you run a 16018 on 8s lipo. The 16018 has problems with 6s and runs comfortably on 5s. Are you sure you're not mistyping something?
my xt8
I do not want to lower the pinion more than this.
I want to lower the temperature of some ESC.
There are two fans.
Motor and ESC are expensive!
It is already 16018× 2.
16024× 1. I stand.
I bought TEKNO v3 RC8 1515 2.5.
I am not more than enough a fund.
13/48T 70℃ by this run.
MGM USB+ PC max temp
13/48T
now12/48T 60℃ over
Is not there a good method to lower temperature?
I have not used CAP.
I think whether some temperature are lowered and demand advice from all of you.
I have tested it in a123 4s2p.
EOS0610iDUO90% charge.
When the voltage of A123 falls, I am usable in 8s.
However, 16018 A123 is until 7s.
I think that I am broken as run possibility immediately.
Because I am heavy, A123 does not stimulate 2p.
VID 1p.
now xt8 3s2p 5200 lipo.
12/48T
1515 2200KV
Only window 1/3 open now.
I open it fully.
try try try
In the case of 16018.
Does not the capacitor addition come for chilling effect expectation?
