11.08.2008, 08:33 AM
Originally Posted by Arct1k
Doesn't answer the question - If you power up the esc are you getting 5-6v on the red wire?
no
Originally Posted by Just go Play
Set the throttle and brake EPA to 125% or max and if your using a spectrum rx plug a rx pack in until you complete the initial setup. Once that is done you can run the rx off the mgm.
Tried it. did not work
