Originally Posted by e-mike
i know that im off topic...sorry for that... but the mmm is not rated for 200amp continiously??????
Not unless the "special project" MMM is different than the regular one. Could be I suppose, but I haven't heard anything that said different. The 200A rating was just a rumor AFAIK during the time where it was still in development and everyone was speculating on its ratings.
Originally Posted by What's_nitro?
If my understanding of an H-bridge is correct, in order to see the 360A rating, you would need an external ground directly back to the battery. The controller's bridge would not be able to conduct through the motor both ways (internally) if all three FET banks were being used to realize the 360A output. I'm sure I'm missing something here...but it sounds correct in my head.
This is how I see it: The MMM has 36 FETs. 3 phases of 6 FETs for the positive supply, and 3 phases of 6 FETs for the ground connection. At any one time, 6 FETs are conducting power to a coil, and 6 are conducting to ground at the other end of the coil.
In brushed mode with reverse, one phases is not used at all, so the same basic operation as above is used.
In high-power brushed mode, the battery + wire goes directly to the motor + terminal, and you tie all three phases together for the ground wire. Since there are 3 phases of 6 FETs on or off at once, that's 120A X 3, or 360A.
