1512 2.5D vs 3D on 5S? -
11.09.2008, 05:41 PM
I have currently got a 1512 2.5D (2050KV) in my 8IGHT and running it on 5S 5000mah geared at 41mph and it gets pretty hot 180F+ The 2.5D on 5S makes 37925rpm and most people recommend motor rpm's to be between 30K - 35K. I once had the buggy geared at 44mph and it was great (apart from the temp of course) had plenty of speed. Was thinking of giving the 3D a go and see if temps would go down. 3D on 5S makes 31450rpm which is 6400rpm difference. Is the 3D going to be able to run at 44mph or becuase it is a slower motor than the 2.5D it won't be able to run that fast without overheating?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
11.09.2008, 06:07 PM
I ran both the 2.5d and 3d on 5s and there was no difference in heat for me even when both were geared for the same top end. You are definitely running hot though. I would double check your bearings and make sure your motor wires are secure and not fraying inside the can as this can cause heat.
11.09.2008, 06:44 PM
yea i just ran a 2.5d on 5s 4000 geard for 39mph and it never got over 143 with my mm never breaking 95, and it was 70 outside. id do like edumakated suggested and check your bearings and connections and also set your timing on your controller to low or lowest, and set your start power to medium or low which ever works best. these will help lower the motor temp.
"Out of spec" enthusiast
11.09.2008, 08:30 PM
30 -35K is only for feigao motors. Neu motors can go much higher before efficiency starts to drop off.
The 3D has more resistance than the 2.5D, which means it will heat up more at a given amp rate because copper loss = resistance x amps^2 and the 3D has about 1.4 times the resistance as the 2.5D. The only time a higher wind motor will run cooler is if iron losses (energy lost in the magnet) are signficant, but this only happens at high rpms.
And btw, Y winds are slightly more efficient than D winds, so you may be better off going with the 1.5Y rather than the 3D. But before doing anything, try different pinion gears and record the temps each time. A GOOD motor should run the coolest with the smallest pinion gear, and gradually get hotter as the pinion gear goes up. If your motor still gets hot with a small pinion gear, there is something wrong with your motor or setup.
11.10.2008, 12:33 AM
so your saying the 3d is gonna get hotter than a 2.5d on 5s ???????????????
id like to know before teckno ships me my teckno version of the 3d, i could call them first thing in the morning and change to a 2.5d ?????????????
edit*** the 3d is more efficent than the 2.5d, but the resistance is .012 compared to .006 of the 2.5 so isnt the resistance realted to the amount of wire used to make the KV lower in the 3d???? i always thought the lower kv motors had a little more resistance?
some one have a better explanation? ive confused my self reading on this subject....
11.10.2008, 12:44 AM
That may be true, but the resistance you are speaking of is really small compared to the inductive reactance of the coils, so the heat increase will be marginal.
11.10.2008, 01:13 AM
I got my timing set to low and start power set to low. Would changing the start power to medium help at all? Before I changed the diff fluids from 5/10/2 to 7/10/3 and updated the firmware on the MMM temps were usually around 165F. Thinking of maybe putting the front diff back to 5000. I think I amy of overfilled my center diff to so might take that apart and check. Nothing in the drive train seems to be wrong. I just got a 12T pinion in so might give that a try which will gear it at around 38mph but I think that may be a tad to slow for my track. The track isn't huge but the back straight and main straight is pretty long
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
11.10.2008, 08:47 AM
thanks brian,
and wont the 3d pull less amps under the same voltage (5s) than the said 2.5d so it will be running cooler and more efficent, even though the resistance is very slightly higher, the lower amp draw over comes the other figures in the heat equation right?
and for drift, try your start power at medium and see if you notice any difference. but it could be a ton of things, including your drivetrain, and you wouldnt even know it, your gear mesh effects it, the gear mesh of your diffs is important also, take the pinion off and push your buggy on a hard floor, if it doesnt roll 4-5 feet "Silently" with a very light push then id be checking there first. did you check your motor bearings for any play?
my gear mesh was too tight on my front diff awhile back after i redid (too many shims on the wrong side, and my motor was running a good 20* hotter than normal after i fixed that my temps went back to normal.
another thing to look at is it really doesnt matter that the neu is up 170-180 they told me their motors would run fine all day long at these temps, so check your temps and sceduled stops through out your run and after it gets up to 170 see if it goes anyhigher as you continue to run and find out where it tops out, in our 30 minutes july 4th a main my 1515 was running 175 at 15 minutes and at the end of the race it was 173, they will top out like this, and nue told me as long as its below 190 its fine to run them at that temp as long as needed.
11.10.2008, 11:13 AM
My 3d didn't run any hotter than my 2.5d. Also, since the 3d is pulls less amps, I get about a minute or two of extra run time as well. I ran FIVE full packs (20+ minutes each) this weekend on our indoor track and temps never broke 110 on the motor (it was about 45-50. Temps for my 3d usually run below 150 on a hot summer day after 10 to 15 minute main. I also had a 1515 and it always ran at 160-175, but never got any hotter similar to what Rootar is saying. Most of these motors just find a temp that they tend to run at and stay in that range. As long as you aren't getting above 180ish, I wouldn't worry about it but you are definitely running on the high side for that setup. I would break your car down completely (diffs and all) and rebuild it to see if there is any binding or something hidden you can't easily see.
11.10.2008, 12:08 PM
If you are trying to go the same speed and don't change the voltage the avg. amp draw on the 3d will be higher or as high as the 2.5d. You are making each of these motors do the same things and just using different ways to get there. 18.5v is constant so you are gearing up the 3d making any gains a mute point vs the other, larger gearing = higher avg amp draw = additional heat. I'm going to say the 2.5d is the correct motor and something else is wrong iMO, bad connections in the bullets something.. else, do more trouble shooting! I would re-solder all connectors to the motor, look for binds through any shafts etc, bearing issues (diffs or axle) etc etc.. You could always go w/ the 3d and move to 6s lipo if you find nothing.
Im running a Medusa v2 60mm 2000kv on 4s geared for 40 and never get over 130 unless it's mid summer then its about 150 and this is after hours of use (15/48). I am using mechanical brakes though, not sure of your setup.
11.10.2008, 12:19 PM
stum the 3d drawing as many or more amps on 18.5v compared to the 2.5d would only be true if you had extremely high gearing that REALLY REALLY loaded the motor, but only 40mph isnt anything for either of these, so the 3d will definetly draw les amps than the 2.5d on the same voltage. its only marketed as a 70amp motor while the 2.5d is a 78, this is at max voltage but you must take into account when running on the same voltage the 3d Will be more efficent on 5s and up, now getting down down below 5s i dunno how they react as much to the slower rpm because that would be a
large gear up to run the 3d at 40mph on 4s
11.10.2008, 01:54 PM
EDITED **** (wrong thread)
11.10.2008, 05:28 PM
i think most of all high ambient temps are to blame here. what would happen if you shipped it over to somone in the states and they were to test it? my guess it would be around 150F or less. this is whats happening to everyones motor at my track anyway. nitro motors seem to handle it fine but the electrics dont. but that said i got a cheap $30 HC motor of the same kv and length. had just as much torque but after 2-3 minutes of going up and down the street with an 80mm fan over it it was at 180F and climbing... whereas my neu in the same environment is around 100F...
the track seems to heat them up alot more than bashing around the yard, and i think ive figured out why. onmy track at least 99% of the time im on the throttle. thats what heats it up i think. it just doesnt get a chance to rest and cool down. in the yard though, you tear to one end, roll around then gun it again for a short amt of time. anyway thats what i recon is the cause of the temps and i think we just have to live with it!.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
11.10.2008, 06:07 PM
What it really comes down to is what motor best suits the application. If you are using ~15 volt packs, you don't want a low turn 4,000 kv motor just to go 30 mph and you don't want a high turn 1,000 kv motor in order to go 60 mph.
Keep in mind that just because a motor draws less amp geared to go a certain speed, doesn't mean it is more efficient. Efficiency directly relates to how well a motor can hold it's rpm. Otherwise, torque is basically proportional to current no matter what. You could have two 2,000 kv motors and even if one is 50% efficient and the other is 90% efficient, they both will have the same torque per amp. However, the 50% efficient motor will be spinning much slower than the 90% efficient motor. And btw, you can treat a 1,000kv motor with twice the pinion gear size as being equivalent to a 2,000 kv motor, and refer to the torque at the wheels instead.
Another example, if you gear a 1.5D for 40mph, it will create lots of wheelspin and will get up to speed very quickly. It will also draw a lot of current to do so, but not because it's inefficient. The excess amperage directly correlates to the explosive acceleration that the 1.5D will have in constrast to the 3D also geared for 40 mph. Such comparsion with the 2.5D and the 3D will be more subtle.
11.10.2008, 07:26 PM
thats a better example thanks speedyBL
