Originally Posted by hemiblas
I am running the spc cells in my mmm 7xl combo geared for 42mph. They dont run hot at all and they handle the peak currents just fine. What type of speeds are you looking for? The MMM neu motor should be even more efficient then my setup. I use a wattmeter to make sure batts are handling load and up to this point I have about 10 runs of this setup.
I am looking for speeds comparable to my Nitro, so about 40mph give or take. I also believe that the runtime (with the ones I linked) would be at minimum 10 min longer than a 5000mah pack. Right?
-Brett
