George16
Supermaxx
George16's Avatar
11.11.2008, 05:54 AM
And that was my issue with it since I noticed that when I inserted the male connector, undue load was being put on the female connector as it was being forced away from the heat sink.
At least mine didn't give those sparks.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
cheesecake
11.11.2008, 11:28 AM
Originally Posted by RBMike View Post
Just bend the heat sink fins away from the bullits, put some shrink tube on them & run it. At some point Castle will listen to us about this problem (& the fan wire issue).
and then they void your warranty and your stuck with a dead v3
11.11.2008, 11:40 AM
V4 MMM here we come...
RBMike
RBMike's Avatar
11.11.2008, 11:41 AM
Wrong, I did not open the case or solder on the board so how could my warranty be void.
11.11.2008, 11:42 AM
I don't think castle is that stupid.... yet...
cheesecake
11.11.2008, 12:36 PM
how did you bend the heat sink fins?
RBMike
RBMike's Avatar
11.11.2008, 02:00 PM
Just push the close ones away from the bullit. They are very soft & bend real easy.
jhautz
jhautz's Avatar
11.11.2008, 06:22 PM
Talked to CC. Tech support guy agreed that it was probably a short accross the heat sink. They are sending me out a replacement. He told me to open up the case and just put a little shrink wrap around the 6.5mm socket. But there isnt any room to do it. Its tight against the plug. Looks like they are using the solutions developed on here as their tech support solutions now. LOL
Hopefully this one is good. I'm really getting tired of this.
to make it...
or break it...
Silent...But Deadly
e-mike
e-mike's Avatar
11.11.2008, 06:35 PM
good to read..i hope cc could fix this kind of issue
D8t on juice!!
e-mike
e-mike's Avatar
11.11.2008, 06:36 PM
why ???the v3 old so far...simply other kind of problem come out....
D8t on juice!!
Pdelcast
Pdelcast's Avatar
11.11.2008, 07:46 PM
Chicken Little...
Patrick del Castillo
President, Principle Engineer
e-mike
e-mike's Avatar
11.11.2008, 08:19 PM
Chicken Little...
im hard on the mmmv3 and the only thing that ive broke is
......DRIVING SHAFT(traxxas c.v.d and plastic driving)
D8t on juice!!
coolrunnings
11.12.2008, 07:02 AM
Come on castle....please get it right!!! If I have to buy a 400.00 mgm for everything I own I'm gonna wind up in the soup line at our local shelter!
pasan
I <3 RC
pasan's Avatar
11.14.2008, 05:00 AM
When i'll recieve mine, i'll take a multimeter and test the conductivity between the plug and heatsink
Which is what he should've done after the very first spark.
david lamontagn
11.14.2008, 10:44 AM
exact
