11.14.2008, 04:57 PM
A novak 2 cell lipo cut off will work without a problem! Don't know why it wouldn't be compatible. I have one that I have traxxas connectors installed on already, plugs in line with the battery so you don't have to solder anything to the esc. Then it simply plugs into the rx and your esc plugs into the cutoff, program it and your ready to rip! It will blink a light at first when you are nearing the cut off as well as blipping the throttle, then it will do a hard cut off. Worked great for me! If your interested in it PM me, I have no use for it anymore.
