Originally Posted by suicideneil
An amp is an amp, 1000milli-amps is 1 amp. What is this obession with current limiters- they will only hurt your top speed, and any decent/ accurately rated esc shouldnt need one. If you fry the esc due to excessive current draw, then the setup was all wrong, so that needs looking at rathe than trying to stunt the power the esc/motor can produce...
But a lamp is not an amp. Tekin uses LAMPS, f.e. GM uses AMPS when talking about current limits. So one who buys Tekin has to ask about how lamps correspond to amps
There is no obsession, this is technology going forward. It is better to have limiter onboard, you can alway turn it off, but when there is none, it won't work even if you ask on on your knees. Current limiter alows you to set your power according to track, not even touching one screw to change motor, gearing and so on. You can influence your power and torque simply using one button, which protects your batteries, engine and esc by the way. Nothing special at all, really. But if you use it for some time you will see how good it is. Somebody who didn't use it won't know it.
Funny (not really) but today my R1Pro put for test on my onroad drove 2 minutes and started to have problems by full power, I am very, very dissapointed with this ESC at the moment. I set limiter half way, some usuall 2s2p liion pack with 60Amps continuos with mild 4.5T motor and gearing 11.5:1 and Tekin dies.... I really don't know what to think....
