TruckBasher
TruckBasher's Avatar
11.15.2008, 10:08 PM
Finally mounted the MGM 16025 (ver 6.22) on this truck and I must say MGM are equally smooth as the MMM even a slow speed. I pretty much enjoyed it. However I made a mistake, for some reason the break was not enabled or i wasnt able to set it properly so I ended up cutting my test in about 15-20mins...temps were low 112degF on ESC 110degF(max) on motor and 95degF on batts...
Hope the weather will remain sunny so I can do more test...
E-Slayer direct drive to diff
