E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
11.16.2008, 12:36 AM
Originally Posted by pasan View Post
I haven't removed mine. I've kept the power switches on both my MMM and MM. I don't want to bother with taking the lid off and unplugging the battery each time I want to take a 10 minute break from playing with my cars.
Just turning the switch off doesn't cut all power. There is still a slight parasitic draw with the switch off, all the switch kills is the BEC. Leaving your batteries plugged in isn't a good idea, especially with Lipos. If you happen to forget to unplug them you can kiss them good bye! Depending on your setup, usually you can reach under the body enough to unplug the battery. On my E-Revo I can unplug and plug the battery in with the body on, if I had to I can swap a battery with the body on. My mini late-model that I race on carpet has been getting battery swaps with the body on too.
