Unsullied_Spy
Unsullied_Spy's Avatar
11.16.2008, 02:06 AM
The real problem with running 4mm plugs is that there isn't much margin for error -- You probably won't have any issues, but do you really want to risk it?
I'd suggest using a 5.5mm connector as a minimum.
+1. 4mm should work, but 5.5s will handle it much better. I use 5.5s on my 6XL, my 1515 1.5D, and my Medusa motors (when they get here) will get 5.5s on them. I've never had an issue with CC 5.5mm bullets even on the amp-hungry 1515 1.5D.
tc3_racer_001
tc3_racer_001's Avatar
11.16.2008, 06:45 AM
i found i couldnt get my wires into the 4mm connectors, so i had to solder onto the side of them and spread the wire around the outside... didnt have anything else at the time... it worked ok, but they did get a little warm, no noticeable difference to performance though...
unless its a temp solution ,go with bigger connectors!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
