11.16.2008, 12:06 AM
The Mamba motor will run hot. Feigao aren't the best choice for motors, they will also run hot. The endbells are only crimped on, they come off during use and your motor will most likely be junk. To solve those problems you can buy a RC-Monster heatsink clamp. However by the time you do that you might as well step up and spend the couple extra bucks and buy a Medusa from RC-M. I run the 36-50-4800, that has already been suggested to you, on my CRT.5. No matter how I have geared it, it has never been above 125*F, If I'm geared high the MM gets warm/hot but with gearing for about 40MPH on 2s Lipo everything is right where it needs to be. Performance on 6 cell NiMh isn't breathtaking by any means but I assure you that you can still have fun with it, especially if NiMh is what you are used to. The CRT.5 is a great little truck, pretty durable for it's size and the speeds it sees too.
