11.15.2005, 05:26 PM
Well, here I am! :)
If you want to use 3mm screws (they fit the tranny case) then a 3mm drill bit would be perfect.
I use 3mm sheets, but 2.5mm or even 2mm should work for batt trays. As for specs, just meassure your packs, and use a bit of imagination. My first design here is not the best. I would do it different now.
I use some foam stuff with thin double-sided tape for cushioning and anti-slipage duty. Stuff feels pretty similar as the foam on the gorilla products.
As for your spur: Almost sounds as if your other spur is another pitch. If the gears wont fit into each other, then they are no match. btw, those spiky things are "teeth".
Good luck on this project.
