Silver_Flame101
Silver_Flame101's Avatar
11.17.2008, 01:02 AM
If limiting the shock travel is the only fix, then get rid of the velcro. Instead just put a piece of fuel tubing under the piston in the shock. If you want the truck to be lowered 2 cm, then use a 2 cm piece of fuel tubing, or a 3 cm for a 3 cm drop, and so on. It will work much better because outside objects will never touch it or damage it.
4 out of 3 people have problems with fractions.
  Send a message via Yahoo to Silver_Flame101
