I keep chewing up my diff gears -
11.20.2008, 02:34 PM
Do anyone know of a way to fix this I can not keep these gears in one peace
I was thinking about getting the FLM diff case?
Maxamps Lipo's
FLM Savage 5s 5000
Mamba Monster V2
Feigao XL 10
E-Revo 4s 8000Novak HV 6.5
E-Maxx 4s 6000Novak HV 6.5
Speed-T 3s 5000
For Bashers, By Bashers - http://www.BigSquidRC.com
11.20.2008, 02:37 PM
shim shim shim. alloy diff cases help too though.
11.20.2008, 02:43 PM
shim very tight
is the alloy diff case worth the cash $60 x 2 to much
Maxamps Lipo's
FLM Savage 5s 5000
Mamba Monster V2
Feigao XL 10
Speed-T 3s 5000
11.20.2008, 02:48 PM
do you have the hpi alloy diff cases?
11.20.2008, 02:56 PM
K now there are 2 things that can be alloy. i have the HPI alloy diff cases that hold the spider gears and i have the FLM bulks. Between them and properly shimming i have yet to replace diff gears years i have had the truck. Ans the flm bulks have only been on for about 6 months.
11.20.2008, 04:10 PM
The hpi alloy diff cups (hold the spider gears) are a must. I also plan to buy the flm combo case/bulks for my flm chassis. Shimming the ring and pinion properly is a must for any vehicle, especially a heavy monster truck.
11.20.2008, 05:51 PM
I agree with linc, the HPI cast-aluminum diff cups really do help.
My Savage has run on the same diffs ever since I got it used (except I added the diff cups). It's got an extended FLM low-CG chassis, center differential with 100k oil, was using 10s2p A123 (now 9s1p), was using a KB-45 10XL geared for 70mph, and a CC HV-110 ESC.
11.20.2008, 06:04 PM
I do have the hpi alloy diff cups I was looking into the flm combo case/bulks
looks like it the shimming that should fix this I did shim this yesterday will see how this goes
Maxamps Lipo's
FLM Savage 5s 5000
Mamba Monster V2
Feigao XL 10
Speed-T 3s 5000
11.21.2008, 04:18 PM
I use the X diff cases with aluminum cups. Propperly shimmed and I have yet to blow a ring or pinion. I have however fractured a spider. (I have no idea how I managed to do that either).
KillaHurtz
11.21.2008, 05:30 PM
11.21.2008, 08:58 PM
I'm currently doing the Cen Gen conversion. Has anyone else done this and still had a problem with their diffs? I would like to stay away from any aluminum parts, like the bulkheads.
