Thread Tools Rating: Thread Rating: 36 votes, 4.97 average. Display Modes
11.21.2008, 10:53 AM
Sure. Everything that is done is inside the tranny so there is no difference externally. However, one of the main reasons for this mod is to utilize motor brake and reverse. The Tekno setup uses a clutchbell setup which makes the brake not work, so really, the only mod usable with the Tekno is the "pin mod".
laser_cart
04.04.2009, 01:49 AM
Tekno you have to get longer bolts and use spacers between motor mount face plate and struts then get long shank pinion thats what i got to do didn't know it was made that way should have went RC Monster mount
On the pins LOL what is the FOC pins you talked about i will be modifing mine with the two threded ones on each side just wondering FOC or the best you found yet to use
