mohanjude
Need for speed
mohanjude's Avatar
11.22.2008, 10:13 PM
Originally Posted by E-VO-Maxx View Post
You're right, the motor mount is from hm-modellbau (onefive.de).
Michael, the owner did a hell of a job to support me in realizing this Monster-project.
Hermann
I have just purchased this motor mount from Micheal at onefive.de and going to install it on a FG monster truck 2WD - with a Lehner 3080 motor and run it on 12S with a schulze 40.160. I have already done a conversion using a Bolido Plettenberg and a Schzule 40.160. I sent pictures of my conversion and video to Micheal. The biggest problem I have is I can't apply more than 1/3 power before the car spins out of control. So I am going to try my luck on the bigger monster truck.
Are you using the FG pinion and spur gears ? Looking at the picture it is not clear of the pitch of the gears.
The 4WD conversion is it better than using a MCD 4WD rolling chassis? I asked onefive.de if he has the motor mount for the MCD yet and he says it is not ready although he sent me a picture of the test project.
Any further advice on the gearing would be much appreciated.
Mohan
SnoopMaxx
SnoopMaxx's Avatar
11.23.2008, 06:16 AM
The shaft size is 10mm.
10mm is the regular shaft size of the 1/5-6 gas-models so pinion gears are no problem.
Yes he is using the stock pinion and spur gears
Morten SnoopMaxx
Never to old to play
c",)
