thekaboom
11.16.2005, 10:27 PM
Originally posted by Papa
However, if you have nothing IE....charger, packs etc.... you might be better off financialy going lipo right away. Yes there is a learning curve. However the leaning apllies to Nimh as well. If you are in this for a while eventually you will want to go lipo. For a first lipo system theFMA Scorpion Lipo system is a relatively painless integrated system. The initial outlay of cash will be about the same. Charger about $85plus one pack 1p2s at about $135. Three quality matched side by side packs will set you back about the same.
also you recommed the 3200 mah pack or the 6400 mah pack? cause i'm leaning towards the cheaper one. ;)
