would there be any performance gain using a (10s) esc with a 5 s system?
when i went from the MM to the MMM in same buggy there was a huge difference. but if motor draws 100 amps and the MMM is fine with that will a 10s MMMMMMM be any different?
I might be wrong but remembering the old spec that were thrown around(200 amps continuous) the MMMM would be worst for 5s than the MMM as it would have to use higher resistance cap which would be great for 10s but with 5s and less volt it might have more difficulty to cope.
