i guess the balancing tab that max amps sent me was bad...
with my jst balancer i can charge my zippys and rhinos perfectly fine...
but when i try and use the TP adapter it does not work correctly..
question......... with the 6s packs im trying to charge it has 2 different balancing tabs.. on the TP adapter it has 2 different ports also... is there a special way to balance 6s packs? maybe my adaptor isnt messed up?
