Shark413
Shark413's Avatar
11.27.2008, 03:34 PM
Looking good, you definitely want to attach your mount to the chassis from the bottom (as you mentioned). The thickness of your mount is also good because 5052 aluminum is a little on the soft side, but 1/4 should be fine. Nice solution to those that don't have the equipment to machine the center diff bearing hole to make a one piece motor mount. Question, any reason why you have the motor mounting screw holes offset? Just curious.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
