Dadx2mj
Dadx2mj's Avatar
11.28.2008, 03:13 PM
Given that its winter and his esc is thermalling, I doubt a small fan will help too much- that only cures the symptoms, not the underlying issue. I'd ask what the motor temps were also when the esc was running that hot or thermalling.
I agree putting a fan on can only be like putting a band aid on a chain saw wound. That is why I mentioned making sure all connections were good and there was no binding. I tend to forget about it being winter since I am in So Cal and still going out to run in shorts and T shirts.
Just thinking it could just be the part throttle driving and track conditions leading to the heat issue. If all else with the truck is as it should be the fan MIGHT be the answer, or at least worth considering
Blindman Racing
Powered by Mamba 5700
