My V3 is holding up great. I have a couple of 8000mah battery packs though it, but I have run it about 6 times. It has seen some flips, hits, starts, stops and still going strong. Thanks.
My v3 is holding up great. I got 12 full packs through it during practice days plus a full race day and it is still going strong... even the fan! I don't think I have seen temps over 120 on it
I have been running the crap out of mine. 6s with an 11xl in a 6kg savage. Two fans on the motor to keep it cool. The fan on the esc comes on but the temp gun only says the esc is at 100f. I'm sure the esc is probably warmer though. I have now taped my tires so I will see if that lessens the load a bit.
success.... however one lunched and shredded reverse output gear, damn glitching reverse servo. all good now FOC. i guess its time to play "so what will break next"
Success, been running MMM's version 2's in my vehicles since 9/07/08, all runtime was done on the track (racing/practice).
MMM installed in Kyosho ST-RR on 9/3/08 (TeknoNeu 1515/1Y) using ext bec and motor/disc brake combo.
9/7/08 - ran two 4s lipos thru it, no problems.
9/13/08 - ran two 4s lipos thru it, no problems.
9/29/08 - ran two 4s lipos thru it, no problems.
10/21/08 - updated firmware to v1.20
11/06/08 - added v3 case
11/9/08 - ran two 4s lipos thru it, no problems.
11/22/08 - ran two 5s lipos thru it, had custom LVC issue/work around.
11/25/08 - LVC problem fixed.
MMM installed in Kyosho SP2 777 on 9/16/08 (Neu 1512/2D) using ext bec and motor/disc brake combo.
9/28/08 - ran two 4s lipos thru it, no problems.
11/8/08 - ran two 4s lipos thru it, no problems.
10/21/08 - updated firmware to v1.20.
11/06/08 - added v3 case.
11/22/08 - ran two 4s lipos thru it, no problems.
MMM installed in Kyosho Kanai CORR conversion 11/15/08 (TeknoNeu 1515/2.5) using onboard bec and motor brakes only.
11/22/08 - - ran one 4s lipo thru it, no problems.
v3 dead 10 min. Esc temp at the time of death 76f.Castle link will still work though.
Edit: Yesterday at the lhs they had 2 v2s and offered me a deal so good I had to take one.With castles CS what the heck right.So while installing it I looked at the v3 and for some stupid reason pluged it in and the damn thing armed and worked on the bench. I still need to run it though.
