crazyjr
crazyjr's Avatar
12.03.2008, 04:01 AM
I have a set of V.1's, they have a shaved down input, the current v.2's are standard 1/8 shaft size. i have no problems with mine, I crushed both the front and rear Integy upgraded stockers with a quark 125 and a 9xl w/5s lipo. the buggy diffs are much better, however you might need to step up in gear or kv on motor, the diffs are geared different from the revo's. If you are toting at least a 1515 neu and 5s lipo, You need these diffs. racers might get away with stockers, but bashers will like the stronger diffs
