11.26.2008, 02:26 PM
The Neu's and Teckno Neu's are made in the states, and have a few differences from the CC neu's that are made in China, so there's alot of the difference in price right there. There are a few other differences between the two, i've heard that the CC neu has a slightly lower efficiency, which means it would run a little hotter for a given voltage. Other than that i believe that the two use different wraps on the rotor (carbon on the Teckno/neu). All in all if the CC Neu is reasonably close the the performance of the origional Neu's/teckno Neu's then they should be a great motor for the price that they will be at, and its up to you if you want to spend almost twice as much for a marginal gain in performance and possibly quality of construction.
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
