Or void the warranty by bonding heatsink fins to the tubes sides...
I wonder if Castle would customize one for you with fins instead of tubes?
Personally, any exostic cooling method just increases weight and things to go wrong...
I personally am not worried about weight. It will weigh 32.8lbs loaded w/o the esc, tank, small radiator, pump etc... As long as it stays under 35lbs im fine with it.
