Being that the magnet is so strong, you'll have to force the rotor out of the can. Remove the four screws so that you can remove the rear endbell, then press the motor shaft down on a hard surface to push the stator out the back. At this point try and grab it and pull it out. Pliers may be in order, just be careful.
