Typhoon 600 series "6-pole" -
12.05.2008, 01:01 PM
I was wondering if anyone here on RCM besides lutach has these motors? For the price and what you get it seems great. Comes with 6-poles, 36-70 size, choice between 1030kv-2050kv. Ive been eyeing up these motors for awhile but dont know if I should take the plunge and order one or not...
What would you use this in? They are the typical 70mm X 36mm dims (like Feigao), recommended to run in the 35-40krpm range (judging by their recommended voltage), and has a max efficiency of 85%. The one with the highest max power, Typhoon 600-32, is rated for 800w. For ~$83, it just seems like a 6-pole Feigao, nothing special according to specs alone.
Made specially for EDFs units with constant airflow to the motor to keep it cool. It could work great in a buggy, but in a truggy a longer version would be helpful.
Whats so different about it? Looks like its rated for 40k rpm like any other motor
Didnt you only run the hexitronic in your Wayne's pede?
Actually we ran it in the raven a few times to. Only on 2s though seeing that we couldnt fit 4s in the w/o some serious upper strap mods which I didnt want to do at the time.
Someone should hit you on the head . It would've been better if you said, "Sounds like a Mega or a 6 pole Plettenberg". Those are the only motors that I know the Typhoon resembles which are all inrunner (Not an outrunner in a inrunner style case as the 600L is) with Kevlar wrapped 6 pole rotor.
