Go Back   RC-Monster Forums > Support Forums > Novak
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
12.12.2008, 01:47 AM
If you do it run a 2s cut off on the battery lead that has the bec circuit attached to it. If you just use a 4s cut off it may allow the bec side pack to drop to low.
JThiessen
JThiessen's Avatar
12.12.2008, 09:42 AM
I was going to set it up with a jumper across one of the battery leads, and run it on a single battery, with the LVC soldered into to deans on the side that I have the battery attached to (similar to the instructions on the HV for setting it up for a single battery application). So I think that takes the BEC side out of play.
