teknorc
12.12.2008, 03:54 PM
Hello,
We haven't heard about the clutch bell rubbing the spring before. Is the spring properly seated into the clutch shoe grooves? Do you have pics of this that we can check out.
As for the flywheel hitting the brake pads. This is a known issue with the 44mm mount and a 13t clutch bell. We have been using a Dremel to grind down the center diff mount and the brake pads a tiny bit to get clearance. It won't hurt braking or anything, but needs to be done if you are running that combination. Thanks.
Tekno RC - Performance Parts
