Originally Posted by tha5150
thanks Pimp.. there wasnt a manual that came with it. i found one online. guess i should print it out
No prob, good idea to print the manual. Most lipo chargers are very simple, as the charge cycle is simple. Some give you an option to set pack capacity and charge rate seperately, others just ask for pack capacity and figure the charge rate off that (older hyperions for example). No trickle charge rates to set, or cutoff values. Charging lipos is easy, especially with a charger with an internal balancer like you have. Have fun with the lipo, you will never go back to nimh...
