12.16.2008, 02:20 PM
Originally Posted by TexasSP View Post
I would check out the Junfac chassis for the CR01, it has gotten excellent reviews.
http://www.junfac.com/shop/index.php...roducts_id=244
The CR01 is a nice platform and I am considering getting one. Or I may go like JRH suggested and get the new losi tranny with the venom lockable axles and a ladder chassis and build my own concoction.
I look forward to seeing the Navigator crawler. It will be nice to see something different for a change. Too many yota's, jeeps, and clod bodies.
The junfac chassis is nice, but the cr01 axles are too wide to work under most 10th scale bodies without looking funny. Tlt axles are much narrower and should work. I will make my own cahssis, going to use 1/2" square tube, heat and bend it and then cut it in half longways to make a pair of c channel rails. Should look more like a real truck frame and have the added bonus of being free. I plan to use the cr01 skidplate for mounting the tranny and model my side plates of the cr01 units to mimic the link mount locations. Should be a fun project.
The Navigator has a full interior, so I plan to try and hide all of the electronics under the hood and keep the tranny as low profie as possible. Going with a pair of 45t lathe motors, and most likely run 2s lipo. Something like 6-8mph will be fine as it will be in the water quite a bit. Not sure of the wheelbase or tire size yet, as I need the body to do some measurements.
