MetalMan
MetalMan's Avatar
11.21.2005, 08:08 PM
Usually I see Lipo being charged through the main leads, and if balancing is done, then a balancer is hooked up to the multi-pin connector. What I do is charge to ~4.15v/cell or higher, depending upon how well the cells are balanced. Then I individually charge each cell, just to make sure that they are all well balanced. I do this manually because I don't have a balancer, and I use male JST connectors as taps.
