George16,
what does changing the center diff fluid to 30k but leaving the front and rear the same do? does this make the 4wd better?
I change it to 30K thinking that doing so will prevent unloading of the front tires. We'll see after my initial run. I'll change it back to 10K if I'm not satisfied with it. What your setup on you 8T?
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
