FunkedOut
12.17.2008, 09:57 PM
Well, I can tell you that the front tires are going backward because you put the front diff in upside-down. Just flip it over so the diff spur gear is on the other side of the diff input pinion.
the diffs are in correctly. what i was saying is that the front diff is getting power because if kicks up dirt when i nail reverse.
Are your rear shocks set up very stiff? That will cause more weight to stay in the front on acceleration and so the rear will slip more.
yeah, pretty stiff all around; 2 UE white springs at each wheel with 50wt. i don't think this is the problem, as i've had this setup for a while now and this behavior just started.
How is the F/R balance of the truck? Are the batteries/motor in the stock locations? (sorry, I'm not the E-maxx pro on here :/ )
51% - 49% (F/R). everything in stock location.
Originally Posted by jayjay283 View Post
you could always put this in CD LINK fill it wil diff locker fluid, and all 4 tires will spin the same provided you have the same diff fluid in the front and rear diffs.
the purpose of a CD is to allow the front and rear to spin at different rates. i have the stock tranny that spins the front diff and the rear diff at the same rpm, so the front and rear tires should spin at the same rpm.
