MetalMan
MetalMan's Avatar
12.18.2008, 05:40 PM
I wish it were that simple. Remember that the output shaft goes through that hole, and if you remove too much plastic you can enlarge the opening the output shaft goes through. This isn't good because then the diff won't be supported well enough by the output shafts.
