CRTIM
12.19.2008, 09:11 PM
would this be enough power for the Hyperion eos0610i charging 5s 5000 lipo...thanks again guys
Competition Electronics 14V/23A Regulated DC Power Supply
[CEI3710]
This is the awesome 23 amp regulated DC power supply from Competition Electronics! This highly efficient power supply is both lightweight and compact, making it easy to take to the track. With the maximum current handling capacity of 23A at 14V nominal output, this power supply can run all your chargers, dynos and other equipment with ease! It can easily charge multiple batteries at 5-6 amps each, without breaking a sweat.
Features:
  • Based on switched mode technology.
  • Compact and lightweight.
  • High efficiency and less heat dissipation.
  • Protected against short circuit, over current and over voltage.
  • Forced air cooling and over temperature shut down.
Specifications:
  • Input voltage: 120 VAC (Pre-set) or 230 VAC (Requires internal jumper)
  • Output voltage: 13.8 VDC
  • Current limit: 23 amps
  • Temp. range: 0 - 40 degrees C
  • AC Input: Detachable power cord
  • DC Input: Terminals with tubular hole diameter 0.2" with set screw.
  • Dimensions: 7" x 8.25" x 2.2"
  • Weight: 3.5 lbs.
