Metallover
RC-Monster Spudgunner
Metallover's Avatar
12.21.2008, 04:08 PM
The wheels/tires effect gearing. If you put on bigger tires and don't change anything else, it will make the car faster. It is like adding teeth to the pinion gear. Same thing is true for smaller tires. Using this tip is especially important if you are running a direct drive outrunner setup.
