Originally Posted by himalaya
It might be better to write the setting unit in actual time scale, say xx ms, than in percentage, so that the user can actually KNOW(instead of GUESS) how much effect the ESC is doing.
Sorry Himalaya, Punch control just isn't simple enough for us to display a time scale.
Punch control is non-linear, and designed to keep control of RMS currents. So, for example, it will ramp slower between 10% and 35% than it will between 75% and 100% throttle, even though they both change by 25%.
We could probably display the full-throttle range time, but that would be misleading to the end-user, as ramp times would typically be MUCH quicker than the worst-case.
