12.24.2008, 09:19 PM
Ok, you definately use the 3rd channel. I would have to look at mine, but you have to set the radio for 4 channel in the setup menu, then set ch1 as the master and ch3 as the slave. You can then adjust the direction, and set the mix as cx1. I have a cx1 and cx2 mix which will swin the servos together or opposite. I have a 4 wheel steering setup, so i like the feature. You will have to play around with the radio, I would offer more help, but my radio is at work...
