Ok so R&D continues but I think I'm close?? What you think??
Once I completed the foundation / design I can add that RCM / TDC flare to it… (I'm looking forward to this!)
FYI!
I incorporated the following into the chair today based off recommendations, comments received early today:
(I'm listening and deeply appreciative of your time and comments.).
• Arm rest & helped strengthen the rear push bars (this suggestion came from my DAD!)
• Foot rest (it’s none adjustable) sorry! But I can angel it so it works as a leg rest (not allowing the legs to fall back) if that helps??
• Rear head support (is this correct??) or should I do something different??
• I also added the necessary pathway for the brake system, but I'm drawing a BLANK on how it should works??? Is this a parking brake your referring too?? Or a brake to slow it down?? Do I attempt a brake out of PVC or use other?? If other got any recommendations???
As always thank YOU ALL so much for your time and your HELP on this project!..
Have a great Day!..
Shaun.
P.S.
What else am I missing forgetting about??
P.S.S.
My WIFE wanted to make sure that ask if a 90% sitting angle with a 12% slope is acceptable!, she thinks the seat should reclaim at an angle of 7-10% (less 90%) what do you think???
