wulfgang
12.28.2008, 04:39 PM
Originally Posted by johnrobholmes View Post
An outrunner may spool up slower as compared to an inrunner (more moment of inertia), but this would be no-load. An outrunner has 7 times the commutation cycles per revolution as compared to a 2 pole inrunner, so the ESC can synch it just as fast as an inrunner hooked to a pinion/ spur geardown.
I thought synching had more to do with the magnitude of the back emf reaching a level that is measurable by the ESC. That would make it depend on speed and independent of the number of poles.
Has there been any consistency with how the cells die? In a certain spot in the pack maybe? Have you tried slow charging or discharging of the packs to break them in? I have been running a123 a long time and only had once cell out of 50 die.
I have slow charged/discharged them all twice before running them.
I have not noticed that they die in a particular location in the pack. The last time this happened, the voltages were 3.3, 3.3, 3.3, 3.3, 3.3, 2.6. Everything I can think of that would cause LVC (bad solder joints, too much current, etc.) should not affect the balance.
What about overheating the cells when soldering the tabs? I use a gigantic iron... I think it's 80W, and heat the cell tabs less than 5 secs to tin and then about 5 secs again to solder the wires.
