Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
12.28.2008, 06:13 PM
Originally Posted by rchippie View Post
If you need more just let me know . Did you see my link to the lst forum in my post above ?. Also did you do the gear flip in the tranny ?.
Yep. I did the gear swap. Worst part was that the small screw holing the bevel gear on the idler shaft was tighter than a dick's hat. Had to file the sides flat (it was a button head) and clamp it in the vise to get it out. After that the case has to be slightly modded, about 30 seconds with the dremel. Not a huge gearing difference, but enough to help the limited spur selection for the lst.
I may have to hit you up for some kydex, but i have a few sheets left. I actually used one to make the chassis for my 2.2 crawler, and all of my buddies use the scraps to make mount brakets and such for their trucks. You kydex is all over Slidel!!!
Originally Posted by TwzteD View Post
Alright, But Can You Post A Pic So I Have An Idea?
No prob, I will search it out and snal a few pics. Just used a piece of 2x3 6061 angle and trimmed it to fit. It adjusts using the stock slotted holes on the chassis, which can be a paint in the ass to set the mesh. But it held the hacker motor fine, maybe a touch of up and down flex at the un-supported end of the motor.
Damn you james.
Yeah, yeah, yeah, whatchya gonna do to me, huh?
