kulangflow
Never Fast Enough
kulangflow's Avatar
12.30.2008, 06:39 PM
You might be able to use a budget 4 channel stick radio from a helicopter. Typically the left stick doesn't have a spring for vertical movement.
You'd obviously need to use a different stick for throttle though if you're using that one for the blade.
